I’ve noticed an issue with Lists where a parent’s child list does not always reset the count with the next Parent List.
Examples:
Manually created list within Obsidian:
Main Heading
A Sub
B Sub
C Sub
Main Heading 2
A Sub
If I Copy the list above then paste the list the second parent children do not reset and instead turn into a continuation of the first parent list’s children.
Main Heading
A Sub
B Sub
C Sub
Main Heading 2
4. A Sub
Obsidian Version 1.8.9 (Installer 1.8.9)
macOS 15.4
I noticed as I’m moving some notes into obsidian manually from a PDF and noticed the issue initially with a different format (Academic) with Roman numerals, Letters, and numbers. Then switched to just numbers and when I copied and pasted I knew the issue was a bug.
