```ini
[section]
key=value
- A list item with an indented css block
```css
.foo {
color: blue;
- A list item with an indented ini block
```ini
[section]
key=value
- Another list item that gets the wrong formatting in the editor
The editor (in both live preview and source modes) renders the third list item incorrectly:
The syntax highlighting for the ini code block should end and the third list item should be displayed as plain text (as the second list item does)
Operating system: macOS 12.2
Debug info:
Obsidian version: v0.14.2
Installer version: v0.13.31
Operating system: Darwin Kernel Version 21.3.0: Wed Jan 5 21:37:58 PST 2022; root:xnu-8019.80.24~20/RELEASE_ARM64_T6000 21.3.0
Legacy editor: off
Safe mode: on
The document renders in reading view just fine. This only occurs in the editor in both live preview and source modes.
The block of text is only colored if I nest the block.
For example, considering this .md note:
## Properties file, or `ini`
```ini
[test]
a = b
## Inline
![[2025-02-10#Properties file, or `ini`]]
These block gets rendered like:
As you can see, there is no coloring on the first block of text, but there is color on the second one.
Obsidian version: v1.8.5
Installer version: v1.8.4
Operating system: Windows 10 Enterprise 10.0.19045
Catalyst license: insider
Insider build toggle: on
(tested on my Vault and sandbox vault)
I noticed, it gets rendered correctly if the “Reading” mode is on.
Turn off all community plugins by enabling Restricted Mode
Switch to Default theme
Got same results
Operating System
Linux fedora 6.12.13-200.fc41.x86_64 #1 SMP PREEMPT_DYNAMIC Sat Feb 8 20:05:26 UTC 2025 x86_64 GNU/Linux
Fedora release 41
LSB Version: :core-5.0-amd64:core-5.0-noarch
Obsidian Version
Current version: v1.8.7
(Installer version: v1.8.4)
