Neoloopy: Think in feedback loops, a systems thinking tool in your vault!
Disclaimer
Is this project completely free? Plugin, Yes, Actual App has option for Pro users (Serious System dynamics users)
Is this project vibe-coded beyond the author’s ability to comprehend how it works? Used AI for this heavily since I already have a source code not written in Typescript, but overall logic wise comprehending.
Community Directory: https://community.obsidian.md/plugins/neoloopy
Hello,
I built neoloopy, a plugin for systems thinking inside Obsidian. It turns your vault into a causal-loop diagramming (CLD) tool: you map how variables push and pull on each other (feedback), how systems gets layered (subsystem routing).
It does take some brain at first to think in circular relationship compare linear, but once you get a hang of it, I am sure it will open many possibilities.
The part that makes it feel at home in Obsidian: every variable is a Markdown note, and every model is just a folder of notes plus a small model.json. No database, no account, nothing leaves your machine. Your models stay searchable, linkable, and version-controllable like everything else in your vault. - What this also means is that the entire system is AI-friendly (it goes beyond this when it comes to CLI and MCP, but will leave that for now)
More about neoloopy: https://neoloopy.com
The entire project had just started, so I’d love feedback!
Noticed that the behavior on IOS canvas is not functioning and needs more work. Will be making this isDesktopOnly for now and soon release a working version, sorry for the inconvenience!
Mobile support is enabled. Not 100% satisfactory on getting the focus to work as expected but not a blocker
