I don’t know if I’m allowed to ask about community plug in here so please let me know if I’m not.
So I’ve installed the Autocomplete plugin by Yeboster and it just doesn’t work.
The autocomplete option doesn’t show up on the screen like it’s supposed to, only a “strategy: default” on the status bar, and when I clicked on it, it changed to “strategy: japanese” and “strategy: arabic” then back to “strategy:default” again.
I’ve made sure I have it enabled, and used the short cut Ctrl+Space to try to toggle it, but it still doesn’t work.
Does anyone have the same problem? Is any solution to this? Thank you.
