Hello!
Any JD people here?
I’ve been using Obsidian for my PKM for almost a year. Starting to feel pretty comfortable in my vault. It contains a variety of notes related to life admin, career advancement, projects I’m working on, and just general knowledge and areas of interests.
The problem
That all has been great, but something holding me back has been how I organize my digital life more broadly. In other-words, my once simple folder structure has accrued a certain amount of chaos over many years, as my file management system now spans several devices, hard drives, and cloud storage.
Johnny.Decimal
This chaos has led me to the Johnny.Decimal System. The idea is, you get 10 areas, divided into 10 categories and in each category you get 100 ID’s that can be stored there. That gives you 10,000 slots to work with – though it’s suggested if you use even half of that, you’re likely doing it wrong. But you have this number system AC.ID, where you get 00.00 through 99.99
I like this approach to system and project management. Regardless of how you feel about the actual implementation of JD (i.e. the numbering and the rules about sub-folders and the rule of 10, etc.), there’s clearly been a lot of thought put behind this body of work concerning file and project management.
One thing I find really useful about JD is that it is meant to incorporate all aspects of a system or project. Digital and hard copies; cloud or C drive. When set-up thoughtfully, it’s like a filing cabinet that anything can fit in.
As I build my system
So I guess there’s some obvious ways to make Obsidian work to my benefit in my system inspired by JD: first and foremost as the Index (00.00 in the system). I’m thinking the index is a separate vault from the PKM I described above. But I’m running into some conceptual issues concerning how to integrate my PKM
How you can help
If you have experience with using JD with Obsidian, I’d love to hear how you do so.
Beyond that, I’m curious if you think my current PKM should be considered it’s own system (multiple systems is cautioned against in JD) or if it’s more of an ID within a broader JD system, area and category to be determined.
Thanks!
