Hi!
Which plugins should I use—and how do I configure them—to get the following?
- Flexible organization using “binders,” folders, notes, or pages
- Ability to add images or short videos as page thumbnails
- A gallery view option [without the page text appearing on the thumbnail]
- Easy navigation and daily usability
- Easily accessible basic word-processing features while writing
It seems you are new to Obsidian. If that’s the case, I suggest you to use no Community plugins at all. First develop that knowledge, then, with time, once you find a limitation or discover a need, start thinking of turning it into a base with the help of plugins. Focus on the work first.
If you are not new, I think the following are enough to cover what you mentioned:
- Core plugin “Files”, or the Community plugin “Notebook Navigator”
- Core plugin “Bases”
- Core plugin “Word count”
