I want to give some suggestions to the Obsidian developers,
- If the title is not defined, automatically add title from the first line of body.
- Top bar of the editor, I mean the path locator, there should have a tooltip to change folder location.
- In the editor
add icon, when we click on it should create a new note in same or different folder instead of opening the previous notes.
- In the sidebar, one folder should expand in a time instead of multiple folder expanding. It will help when we click create new note or folder then note or folder will create under the selected folder.
- Notification take a lot of time to hide from the top bar, for that we can’t access top bar anything.
Lastly, When I select text from the web or other apps and try to share it to Obsidian, there is no option to select a folder, but other note-taking apps have the common feature. It’s so annoying when it comes to taking notes.
