There are hot keys to switch between the different panes. Called navigate back and navigate forwards.
When you do you see a highlight moving from one pane to the other pane.
  • Select the left pane and have your cursor be ready to write something.
  • Navigate forwards to the next pane. You can see the highlight at the top of the pane.
  • Write something.
You’ll end up writing something in the left pane even though the right pane is the pane that is active.
When you write something in the active pane it will happen in the active pane and not somewhere else.
After switching pane, the cursor doesn’t follow but stays in the inactive pane.
  • Operating system: MacOS
  • Obsidian version: 0.6.7
  • Using custom CSS: Yes.
please be more specific because I can’t reproduce.
If you can record a short video/gif that would help.
Gif here -> https://recordit.co/yweqgifsXT
thanks!
Please let me know if you have this issue when we release 0.7
Will do!
This seems to be working now!
