Just seconding that this functionality is important - selection via the arrow keys would be ideal, numbered hotkeys also seem reasonable. Is there any alternative currently to get this functionality without a mouse?
please please please please please add this
this feature is absolutely critical.
How do other users search and navigate their notes? using the mouse???
Ideally first result should be actionable with enter key while the focus stay in the search box for further input if needed.
I’m somewhat shocked this doesn’t exist. I wouldn’t even consider using an electron app normally, but obsidian works surprisingly well. This is a shame though, at least tabbing must work, just like in other apps.
Absolute must have. ![]()
Please rank that high on the to-do. It’s just a shortcut so not a lot of work anyway. This thread is from 2 years ago…
It seems crazy that such a thing isn’t easily doable - from both an accessibility and productivity point-of-view!
I only just discovered today, the community plugin “Core Search Assistant” can navigate search results via keyboard, with shortcuts you can remap. (ctrl+N and ctrl+P by default. ctrl+enter to open the note.)
It can also show card previews of your search results, which is pretty cool for seeing context, including images!
As you said It is possible to do a search without using the mouse.
This issue is about the fact that without the mouse it is not possible to:
- Open the files found by the search
- Leave the search pane
This feature is absolutely needed
Just installed and tested a bit:
- does NOT work with the build-in quick switcher
- works with Quick Switcher++
- doesn NOT work with the dropdown menu from Tasks
For auto-completion I use obsidian-various-complements-plugin which provides shortcuts for selection.
and The Oscar goes to “Core search assistant plug-in” ![]()
Overall increase full keyboard navigation. This in particular:
After typing in a search team, allow up and down arrows to move through search results, and ENTER to select one to open.
Seconding this! It would make my workflow so much more efficient! Plus maybe an option to have a little pop-out preview of each one and then actually open it and put the cursor at the bottom of that note when enter is pressed. That way people wouldn’t accidentally switch to the wrong note.
+1 It would make my workflow so much more efficient too.
+1 ![]()
Because I access my notes in another apps primarily through searching, I got used to navigating my search results by arrow keys and Enter so much, that searching in an app, which does not support it feels SOO WEIRD
Related feature requests:
- Support for using up and down keys to navigate search results - #2 by esm90
- Navigate search results without using the mouse
- requests multiple features, including this one, makes sense to keep it separate.
- Keyboard-friendly Find (ESC behaviour)
- Iterate through files in the file sidebar with keyboard
- Selecting search results with keyboard
- https://forum.obsidian.md/t/tab-navigation-from-search-in-all-files/122
- Customizable keyboard shortcuts to toggle active visibility for 'File Explorer', 'Search', 'Tags', 'Starred'
- Retain search query on focus (0.8.0)
@moderators Great list of duplicate feature requests — should all be merged to the master thread:
Pressing tab after a search via ctrl + shift + F moves the cursor to the header of the leftmost panel (I believe). I would expect it to move to the search results so that it is possible to navigate between them with up & down keys.
Giving my +1 vote to this. Dramatically slows down productivity / efficiency when you have to take your hands away from the keyboard to select what you’ve searched for.
