I can see this being a useful feature. Being able to drag-drop headings in the outliner would make it easy to reorder note sections.
You can rearrange sections by dragging headings around in the default outline â even on mobile! (I donât know if this was true back when the original request was posted.)
This looks awesome!
Would love to see Obsidian or a plugin dev take inspiration from Gingko ![]()
One could replicate such setup by opening three (or more) side-by-side panes in Obsidian and utilizing internal links (kind of like nested MOCs), though navigation between notes wouldnât be nearly as smooth as in Gingko, which âremoves friction from âdrilling downâ into detailâ and allows âto create a multi-level journal so that you can get line-of-sight from years, months, weeks, to daysâ, as Andy Matsuchak put it.
I support the request in the OP as well ![]()
Edit: turns out thereâs a great Gingko-inspired plugin already: Lineage. Though one thing I donât like about it is that it contains a whole project to a single source note, which is hard to navigate when viewed as a regular note (unless you add a heading to each âcardâ manually, which is cumbersome).
Also, itâs more suited for starting a writing project from scratch and less so for structuring an existing collection of notes. I wish it could map onto an existing nested folder structureâthat is, each âlevelâ in Gingko would be a regular Obsidian folder, with each of its separate notes being its own âcardâ. Each subsequent level in âGingko viewâ would be that folderâs subfolder, and so on.
Iâll make sure to write up feature requests for the auto-insertion of headings to aid navigation, and for such a âfolder modeâ. As of now, Canvas seems like a better fit for that sort of workflow.
