- In the Sandbox vault, create a .base and add a custom formula column.
- Embed that base in a note.
- Right-click to edit formula → all good!
- Disable Settings > Appearance → Native menus.
- Right-click to edit formula doesn’t appear/reliably trigger.
Did you follow the troubleshooting guide? [Y/N] Y
Right-clicking on a formula column shows the formula popup.
No popup.
Obsidian version: v1.9.7
Installer version: v1.8.10
Operating system: Darwin Kernel Version 24.6.0: Mon Jul 14 11:30:29 PDT 2025; root:xnu-11417.140.69~1/RELEASE_ARM64_T6000 24.6.0
Catalyst license: supporter
Insider build toggle: on
Plugins installed: 0
Plugins enabled: 0
- this doesn’t happen in a .base file, only for embedded bases.
- there’s a clearer clip on Discord where you can see the formula editor flash slightly at times.
- the same on two Macs; haven’t checked on Windows yet.
- if I keep clicking
Edit formula… the menu eventually does show up (every 7~10 clicks?).
