Scrolling the first preview pane or second edit pane with nice synchronicity. The center of the text in the editor must be on the same level as the center of the rendered image, I suppose.
Video with bag: Bug report 2021.12.25 | Obsidian.md v0.13.14 - YouTube
This is not a bug. Obsidian tries to maintain the alignment on first line of the document using the markdown blocks as reference points. If you don’t separate the lines with black lines, you only have one big markdown block.
Are you planning to add a special rule for images in view mode?
@WhiteNoise
