Narrow column contents breaks single word column header over multiple lines
Describe the bug
When there’s a column with very narrow content, the header label (a single word) gets broken across multiple lines
To Reproduce
Steps to reproduce the behavior:
  1. Create a table with two columns
  2. Put in a normal length word as the column header for both columns
  3. Add a 1 char string to column 1, and then a long string to column 2
Expected behavior
Ideally I’d love to be able to specify column widths (or even drag to resize :pray: ), but it’d just be great if the column sizing wouldn’t split a single word over multiple lines (especially if that word is <40 characters long)
Screenshots
System:
  • OS: OSX 12
  • Obsidian Version: v0.14.6
Additional notes
I’ve already checked, this isn’t an Advanced Tables bug.
was fixed in 0.15.4
