My web clipper templates
Github
Download all the templates and required snippets on my repo. Follow and like because this is the place where templates will be updated. I recommend you to subscribe (watch) this thread to get updates in your email.
Templates for the web clipper extension for Obsidian.
Just copy the json files content to import in the web clipper.
Snippets
Don’t forget to download the snippets that go along with the templates you need. How to
History
Last update: 2025-02-25
  • fix (youtube): channelUrl was missing sometimes
  • feat (youtube): handle timestamps links in description
About Twitter/𝕏
This template is meant to archive tweets that match the url https://x.com/some-user/status/tweetID. It saves tweet and quote, the images and gif but currently can not save the videos. Follow and add a thumb up to this issue to know why and if it is fixed.
This template is currently a workaround because the available variables are not numerous or always right. Follow and add a thumb up to this issue to know why and if it is fixed.
But the result is good.
screenshot
Thanks for sharing, this will come very handy.
Update 2025-02-25
@Fred_V Great templates. Thank you! What about same for LinkedIn and Facebook?
I don’t need them so I won’t spend time to do it. But you can do it yourself.
Would you make a template for Youtube Shorts?
Is there an updated x. com template? The one at Fred-Vatin repo gives a ton of errors :frowning:
Nope. I don’t really use them for now. I don’t have much time to spend on it but PR are welcome.
