Attempt to follow these actions, as described in Obsidian Help:
Arrange cards
Selecting a card moves it to the front.
Press
Spacewhile moving a selection to disable snapping.
Resize a card
You can press
Spacewhile resizing to disable snapping. -
To maintain the aspect ratio while resizing, press
Shiftwhile resizing.
Disconnect two cards
Hover the cursor over a connection line until two small circles appear on the line.
Connect a card to a different card
Navigate a connection
If two connected cards are far apart, you can navigate to the source or the target of the connection by right-clicking the line and then select Go to target or Go to source.
Y
For the actions to work as advertised.
Numbers denote the corresponding step in Steps to reproduce:
- I expect a card to remain being brought to the front even after itâs no longer selected. (From the description, itâs unclear whether a card moves to the front only while selected or permanently. A more precise language is needed.)
- Does not. But holding down Ctrl does.
- Ditto.
- No effect.
- No âtwo small circlesâ ever appear.
- Ditto.
- No such actions in context menu. Instead, a single action existsââFollow connectionâ.
Obsidian version: v1.7.7
Installer version: v1.7.7
Operating system: Darwin Kernel Version 20.6.0: Thu Jul 6 22:12:47 PDT 2023; root:xnu-7195.141.49.702.12~1/RELEASE_X86_64 20.6.0
