Multiline block reference?
Is it possible to have a multiline block? instead of having only one line, paragraph, etc. I’d like to be able to embed an entire segment.
ie.
- hello
    - world
    - hello
        - world ^block-id
Then I would do
![[document^block-id]] which would in turn show the entire segment:
- hello
    - world
    - hello
        - world
instead of just showing
        - world
Is that feasible?
Thanks!
Try moving the blockID reference higher to see what scope is available.
At a push, you’ll need to make a heading level above the first line in the hierarchy and reference that.
I tried this:
- hello ^block-id
    - world
    - hello
        - world
and that:
# hello world ^block-id
- hello
    - world
    - hello
        - world
and both only embedded a single line :person_shrugging:
Are you missing the # symbol?
If I have a document
# hello world
- hello ^04ceaf
    - world
    - hello
        - world
I can embed the following blocks
![[document#hello world]]
![[document#^04ceaf]]
To embed the whole list, put the block ID below the last list item, separated by an empty line, like so:
- hello
- world
^id
Without the empty line, the block ID will apply to the last list item only:
- hello
- world
^id
For headings, block IDs like:
Heading ^id
and
Heading
^id
will only show the heading itself, not the content under it. To also include content, use [[Filename#Heading]], though the links are liable to break if the heading gets renamed, unless using the “Rename this heading” command.
Thanks! That’s what was missing. I never realized I could embed entire headings.
Also @peeragetalkers’ way of putting an id under the block does work as well!
So I went from no way to achieve what I wanted to two ways of doing so!
What’s funny it’s that I used to link to headings but never realize I could use the same syntax to embed them. That makes my day! Thanks to the both of you!
