Multi-line bullets intermittently lose indentation of lines after the first
  • Edit a file in live preview node, ideally one that already contained a bunch of nested bullet points, with multiple lines of text in each bullet.
  • After adding a few new bullets, scroll around the file.
  • A few (usually a small number) or bullets may end up with the issue, having the second and following lines of that single bulleted paragraph lose their indentation, and instead appear aligned further left than they should as a part of that bulleted paragraph.
  • This is, unfortunately, intermittent, and is often (temporarily) resolved after closing and reopening the file or after moving the cursor to the bulleted paragraph and pressing the arrow key to pass the cursor over it and then out of the block (causing the bullet to switch to edit rendering temporarily, then back to preview rendering).
  • Note that which bullets in a file this issue occurs for is also inconsistent.
Yes. I copied one of my files into sandbox, worked on it there for a while, and an hour later, found this:
See the 4th line of text (second line of the second bullet).
I expect my formatting to be consistently consistent, and not “randomly” lose indentation for individual paragraphs in my file.
See the 4th line of text (second line of the second bullet) in this screenshot of the issue:
Obsidian version: v1.11.5
Installer version: v1.8.4
Operating system: Windows 11 Home 10.0.26200
This video shows me hovering alternately over a normal bullet and then over a “broken” bullet with my mouse while using the “Inspect” functionality of the dev tools brought up with Ctrl+Shift+I. Note that the displayed/highlighted bounds for the element are, for some reason, different.
Updating this to say it’s still an issue in the current version, and to show an especially egregious case I just had happen.
What this should look like (and what it does look like after I force it to correct itself) :
I have the feeling that this is a variation of this bug.
This is difficult problem and I am not sure it will be addressed anytime soon.
Also, try to download and reinstall Obsidian.
Already done in the meantime since the original post, just in case. I worked in a fully default setup on a fresh install for a while to get a feel for whether it would be more or less common without my addons and CSS, and the issue was still apparent, occurring at about the same frequency. This was also reproduced in the sandbox vault (as mentioned in the original post).
I hope it will be addressed someday, but I do appreciate the clarity and openness about how likely this is to be addressed in the short term.
