Multi-colored nodes in Graph view
Nodes in Graph view are colored using different tags. Right now, a node can only have one color, even though there are multiple tags with different colors assigned to it.
Add a feature which alows a node to have up to 4 colors like in a pie chart, so you can clearly see its assignment of multiple tags when zoomed in. When zoomed-out, make it the first mentioned tag color, since the 4 colors won’t be visible clearly at one point.
If a plugin is fine for you: Tag Graph (I’m the author) draws a note with several tags as a small pie, one slice per tag, up to four, which is close to what you sketched. It runs inside Bases rather than the core graph view, so it shows the notes of one base at a time.
