Hi, I just noticed this. I’m not sure if it’s 1.0.0-specific…
The original file (left) has a series of callouts with a space line (not >) between each.
However, when transcluded (![[Spark#2 Learning Grow Your Brain Cells]]), the blank lines are not rendered when in Edit mode, only when in View mode (right). This makes it look like it’s one big call-out.
The problem does not manifest when blockquotes are used. Then, the appropriate blank lines are rendered between quotes in both modes.
Another user reported not seeing this issue whilst mobile but, for me, it’s also manifesting on mobile (this example shows a switch to different call-out types, but still there is no separation)…
Anyone else seen this with any version?
