Moving backlink pane to top of note
I was looking for a way to move the backlinks pane from the bottom of the note to the top. I feel it fulfills a role similar to breadcrumbs, which i can’t get working right. Is this possible? with css perhapsß I don’t have any programming knowledge.
UPDATE:
This is the CSS i came up with, its janky:
.cm-sizer {
    display: flex;
    flex-direction: column;
.inline-title {
    order: 1;
.metadata-container {
    order: 2; /* Metadata should come third */
.embedded-backlinks {
    order: 3;
    position: static;
    overflow-y: scroll; /* Enable vertical scrolling */
    height: 300px;
    .tree-item-icon {
        padding: 10px 85px; /* Increase the padding to make the area larger */
/* Make sure any other note content stays in order */
.cm-contentContainer {
    order: 4;
