Move right hand side bar to left?
Hi, is it possible to reposition the right hand side pane (the one with backlinks, tags, outliner etc) over to the left hand side so it is next to the pane where files/folders sit? Is so how?
Thank you
It isn’t possible to reposition the actual pane, but the elements (backlinks, tags, outliner, etc) can be dragged and dropped individually to the left pane: just select and hold the icons and start dragging.
Thank you Eightning. I should stop trying to make Obsidian look like Evernote perhaps :slight_smile:
