Hi
How can I add the graph and file properties icons on the right upper side of Obsdian?
The screenshot has an example of it.
Hi
I updated your title to clearer depict what you’re asking for, but I’m not quite sure I understand your request still.
Do you want to have the global graph icon as part of the toolbar of the right side pane? Maybe the Commander plugin is capable of moving that there.
Regarding the file properties icon, I think it should suffice to open up the command palette and execute the command: Properties view: Show file properties.
Does this answer your questions?
I’d like to relocate the graph icon and add a file properties icon to the top right corner.
I attempted both actions for the two icons, but they didn’t move to the desired position in Obsidian
You can open either Graph view and drag it to the sidebar.
https://help.obsidian.md/User+interface/Drag+and+drop
https://help.obsidian.md/User+interface/Tabs#Arrange+tabs
For the Properties view in the sidebar, that needs to be enabled in Settings > Core Plugins. If it’s not there, you can run the command holroy mentioned above.
Understood, the graph icon is functioning properly now on the right sidebar. However, the one I referred to isn’t the ‘all properties’ icon; it’s actually the file properties icon. Could you please take a look at my screenshot? Either way, thank you very much for the excellent explanation.
There are two commands for Properties view:
I’d suggest looking through https://help.obsidian.md/, what comes up in the command palette, Settings > Hotkeys (many are unassigned), etc.
Ohhhh! Sure! I appreciate it.
