More reading mode navigation options (vim gg and G)
as an ipad user, i’m requesting navigation hotkeys exposed for reading mode navigation.
as far as i can tell, there isnt many options for navigation in reading mode. especially on mobile. my only real option is finger gestures.
at a minimum, i’d like hotkeys to scroll to the top and bottom of the document. i’d be extatic is you added the classic vim gg and G motions. but i’d settle for hotkeys i could bind to like ^home and ^end
ideally also adding block movement selectors as well. jumping between titles, or sections of the rendered view.
as a stop-gap, i’m using the reading view enhancer plugin which works for navigating blocks very well, but is limited to that. i’d love to see a 1st party solution
