Modal Forms input (multi-select pages) to Links in YAML
I’m making a template for journaling/diary, and I am using modal forms to help abstract the process into a simple form. I’m using Templater & Modal Forms to do so.
Some of my form’s fields are a multi-select that allows me to select a note from a folder (ex: people, places, pages). I want to take the result of those fields and turn it into links in the YAML header.
Currently, whenever I input multiple pages into these fields, my links clump up into this:
:x:"[[person1, person2]]“,
when I am aiming to get this:
:heavy_check_mark:”[[person1]]" “[[person2]]”.
Example of my properties when I input multiple results into the field:
Current Template:
Perhaps there is some way to separate them so I can link them independently?
Edit: in addition to the above problem, is there a way to “hide” a property if the form for it is left empty? Example:
Current: person: ""
Desired:
(should not show the property if empty)
I sporadically jumped around the Modal Forms documentation, but I didn’t see anything regarding splitting up the result of multi-select fields.
I also searched for other forms on Reddit and here as well, but I didn’t find anything regarding my problem.
Desired Outcome:
I have exactly the same problem. Did you figure it out?
