Modal close (x) buttons do not work in mobile android
install a community plugin that has a pop up window like this when you enable this plugin it will open a pop up window that has that close button at top right and clicking on it will not do any thing
close the pop up windpw
does not close it
Operating system: android 14 (samsung SM-A725F)
Webview version: 139.0.7258.160
Obsidian version: 1.9.12 (237)
API version: v1.9.12
Plugins installed: 1
Plugins enabled: 1
1: Remotely Save v0.5.25
we don’t take bug reports involving third party plugins.
Open a bug report in their github repository.
it’s for all plugins the close buttons not just that plugin any pop up tht has this x does not work
Does it happen on Core Plugins?
I could not find any core feature in mobile that shows a pop up but in any community plugin that does it does not work
like these
We’ll double check this in the API.
will be fixed 1.9.13. No ETAs.
