Go to the display settings and try to scroll all the way down on the mobile app to adjust the link distance. On my Samsung Galaxy s24 ultra The link distance option is barely showing and is not able to adjust properly.
I would like to display menu to just simply scroll down a little bit further so that I’d have better access to the link distance setting. Along with anything else that might be down there that I can’t see at all.
As I’m scrolling down to the bottom of the display settings on my graph for you The menu just doesn’t seem to want to scroll low enough it stops before it gets to the bottom.
Operating system: android 14 (samsung SM-S928U)
Obsidian version: 1.6.7 (149)
API version: v1.6.7
Catalyst license: none
The link distance feature won’t seem to show up properly on my Samsung Galaxy s24 ultra. The bar is barely visible down at the bottom, and I can’t scroll any lower to see it better. Sometimes I can get it to change but I can’t really control it right now. I don’t know if there’s anything else supposed to be lower than it as well.
