Starting maybe a month ago, I get these warnings when I open Obsidian in my PC (Win 11)
They seem to involve graphs. Around the same time I noticed that the graph screen wasn’t available at the usual place, and I had to press Ctrl-G to see the graph.
Thanks for any help
A plugin is causing this. Disable that plugin (or fix it), and the error will go away after a restart.
thanks, it worked. Actually I disabled and then enabled and updated the “webpage html export” plugin, which fit the warning description and which I had installed I guess about the time the warnings appeared, and the warnings went away.
(I haven’t yet used the plugin by the way)
