Copy the following snippet into the Obisidian Sandbox, and make the width such that the string following the last bullet point wraps.
- testString
- test string for when the line is long, but the wrapped characters are not consecutive
- test string for when the line is long, and the wrapped charactersare consecutive
- test-string-of-when-the-line-is-long,and-the-wrapped-characters-are-longer-than-the-width-of-theline
- testStringOfWhenTheLineIsLongAndTheWrappedCharactersAren'tSeparatedByHyphens
Y
I expected the string which follows the final bullet point to wrap, so that second line begins at the same x-index as the first line.
Instead, the second line begins to the left of the beginning of the right line, and the bullet point is shifted to the left (losing its alignment with the previous bullets).
Obsidian version: v1.5.12
Installer version: v1.4.16
Operating system: Darwin Kernel Version 23.4.0: Fri Mar 15 00:11:05 PDT 2024; root:xnu-10063.101.17~1/RELEASE_X86_64 23.4.0
Catalyst license: none
This formatting peculiarity also occurs with numbered lists.
I figure this situation is probably uncommon. I stumbled across this potential bug taking notes about a repository that had some long method names.
Super fan of Obsidian!
