- Open new note
- Create two H1 headings, one above the other, with one line between (with content or not)
- Minimise (toggle hidden) the top heading, which should hide the whitespace/content between the two
- Add a new line after the minimised content
- Reveal then re-minimise the top heading
- Notice the whitespace/content added under the initially minimised content is now hidden.
Additional whitespace below the hidden / minimised heading will not be toggled to hidden when content is hidden
Any additional hidden content (whether added after the initial content is hidden or not) is ‘swallowed’ by re-toggling the display of the initial content
Operating system:
MacOSx 10.14.6 (Mojave) -
Debug info:
Obsidian version: v1.1.16
Installer version: v0.15.8
Operating system: Darwin Kernel Version 18.7.0: Tue Jun 22 19:37:08 PDT 2021; root:xnu-4903.278.70~1/RELEASE_X86_64 18.7.0
Catalyst license: none
Legacy editor: off
Community theme: Things v2.1.6
Snippets enabled: 3
Plugins installed: 8
Plugins enabled: 8
1: Obsidian Columns v1.4.0
2: Icons v0.3.0
3: Icon Folder v1.7.0
4: Custom File Explorer sorting v1.7.1
5: Obsidian Git v2.19.0
6: Dataview v0.5.55
7: Advanced Tables v0.18.1
8: Kanban v1.5.2
Can provide video if the above isn’t sufficient, though it’s a bit of extra effort.
I tried this in sandbox vault and had same issue exactly.
