Minimal Properties
This CSS snippet makes for a tidier appearance of Properties:
Screen Recording 2025-08-29 at 16.09.48
  • On desktop, the Properties label is revealed only on hover and when folded.
  • Add property and x buttons, as well as property icons are hidden in Reading view.
  • The margin above the Properties block is shrunk.
  • The Empty placeholder is replaced with an ellipsis ().
Each modification is clearly labeled in the code: you can pick what you like and delete the rest.
I also included a few other options which are disabled by default; uncomment them to try them out.
CSS snippet
[Properties]_Minimal.css (4.0 KB)
/* Source: https://forum.obsidian.md/t/minimal-properties/104415 */
/* Last updated 2025-11-21 */
/* 'Properties' label modifications */
/* Hide when unfolded (desktop)
body:not(.is-mobile) .metadata-properties-heading:not(.is-collapsed) .metadata-properties-title {
    opacity: 0;
    transition: opacity 0.2s ease;
/* Show on hover when unfolded (desktop)
body:not(.is-mobile) .metadata-properties-heading:not(.is-collapsed):hover .metadata-properties-title {
    opacity: 1;
/* Always show when folded
body:not(.is-mobile) .metadata-properties-heading.is-collapsed .metadata-properties-title {
    opacity: 1;
/* Replace 'Properties' label with 'YAML' */
    font-size: 0;
.metadata-properties-title::before {
    content: "YAML";
    font-size: 1rem;
/* Replace 'Properties' label with Lucide info icon
    font-size: 0;
    content: "";
    display: inline-block;
    width: 16px;
    height: 16px;
    background-color: var(--text-muted);
    mask: url("data:image/svg+xml,%3csvg xmlns='http://www.w3.org/2000/svg' width='24' height='24' viewBox='0 0 24 24' fill='none' stroke='currentColor' stroke-width='2' stroke-linecap='round' stroke-linejoin='round'%3e%3ccircle cx='12' cy='12' r='10'%3e%3c/circle%3e%3cpath d='M12 16v-4'%3e%3c/path%3e%3cpath d='M12 8h.01'%3e%3c/path%3e%3c/svg%3e");
    -webkit-mask: url("data:image/svg+xml,%3csvg xmlns='http://www.w3.org/2000/svg' width='24' height='24' viewBox='0 0 24 24' fill='none' stroke='currentColor' stroke-width='2' stroke-linecap='round' stroke-linejoin='round'%3e%3ccircle cx='12' cy='12' r='10'%3e%3c/circle%3e%3cpath d='M12 16v-4'%3e%3c/path%3e%3cpath d='M12 8h.01'%3e%3c/path%3e%3c/svg%3e");
    mask-size: contain;
    -webkit-mask-size: contain;
    mask-repeat: no-repeat;
    -webkit-mask-repeat: no-repeat;
    font-size: 1rem;
    vertical-align: middle;
/* Reading view modifications */
/* Hide all x buttons */
.markdown-reading-view .multi-select-pill-remove-button {
    display: none !important;
.markdown-reading-view .metadata-property .multi-select-container .multi-select-pill {
    padding-right: 0.65em;
.internal-embed.bases-embed .multi-select-pill {
/* Hide property icons */
.markdown-reading-view .metadata-property-icon {
    display: none;
/* Miscellaneous */
/* Reduce margin above the Properties section
.metadata-container {
    margin-top: -1em;
/* Hide property icons in all views
    display: none;
/* Replace 'Empty' placeholder with ellipsis (…) */
.metadata-input-longtext[placeholder="Empty"]:empty::before,
.multi-select-input[placeholder="Empty"]:empty::before {
    content: "…";
    color: var(--text-faint);
.metadata-property-value {
    position: relative;
.metadata-input-number[placeholder="Empty"]::placeholder {
    opacity: 0;
.metadata-property-value:has(input[placeholder="Empty"]:placeholder-shown)::before {
    content: "…";
    position: absolute;
    left: 7.25px;
    top: 50%;
    transform: translateY(-50%);
/* Shorten 'Add property' button text to 'Add' */
.metadata-add-button .text-button-label {
    visibility: hidden;
.metadata-add-button .text-button-label::before {
    content: "Add";
    visibility: visible;
Also, Pretty Properties allows to hide some properties from view (they will remain visible in Source view).
How to add a CSS snippet - Obsidian Help
Relevant feature request:
Also works great with Bases embedded in-note — prevents property value deletion via accidental clicks on x, after which you wonder ‘so what did I even delete just now?’
Updated to not hide the label on mobile, and to make compatible with colorful properties added by Pretty Properties.
