I posted about this on the subreddit, but figured that I would try reaching out here as well.
I am looking to find either a setting/method/plug-in that automatically closes subscripts and superscripts.
For example, when writing subscripts I’d like to type (without the spaces):
< sub >
and then have the program automatically append:
< /sub >
to the right of my cursor so that I can continue typing what I am subscript-ing.
This might be more complicated to implement than I am imagining, but the program already automatically appends quotes and parentheses after the opening symbol, seems like a logical extension of the functionality to me.
I am new to markdown, so apologies if this is a well established function (or lack thereof).
I have looked around here on the forum, as well as done some exploratory Googleing, but found nothing.
Thanks in advance for any advice!
It’s not built-in to auto-close HTML tags, but you can use the Text Snippets plugin.
I have, for instance, these text snippets defined:
kbd : <kbd>$end$</kbd>
sup : <sup>$end$</sup>
sub : <sub>$end$</sub>
This allows me to type sub, press the defined expansion key, and voilà, it will insert <sub>|</sub> and place the cursor where I put the | here.
That’s perfect. Thank you for the recommendation!
Happy to help, glad you can use it!
