I am reading the documentation here specifically: Buttons | Meta Bind Docs
I am simply trying to uses the templaterCreteNote type in meta-bind-buttons to create a simple template note, using my Default Template Note for testing, as I am learning this for the first time. Form what I can see I did do everything correct.
I followed the example given in the documentation for templaterCreteNote, as well as read the introductory documentation on [meta-bind-buttons.](https://www.moritzjung.dev/obsidian-meta-bind-plugin-docs/guides/buttons/) I just replace the example templateFile field with my own, but got an error. I don’t understand.
