Meta-bind button to create note from template, then direct me to meta data to be filled out
I am trying to create a meta-bind button that will create a note from template, then direct me to the meta data to be filled out. This is what one of my buttons current looks like:
style: primary
label: Create Default Project
hidden: true
actions:
  - type: templaterCreateNote
    templateFile: "8. Meta/Template/Project Default Template.md"
    folderPath: /
    fileName: "Project Default Template"
In the above example is my project template creation button. I would like to be able to fill out metadata prior to the template being created. I have seen other user of obsidian do it, and just would like to know how the trick is preformed
I have read meta-bind documentation prior to submitting this post.
I fixed the broken formatting in the post (code blocks need to start on a new line) and changed the title to tell people what you’re looking for (was “Metadata”). Good luck!
Thank you so much.
tp.system.prompt or tp.system.suggester was the solution.
