Hello! I’m trying to create a diagram using MermaidJS and i want to use some MathJax with it. If i try to do it using the Live Editor linked in the docs it works. But when i copy the same code to Obsidian the MathJax part is rendered as simple text.
This is the code i’m using:
graph LR
subgraph Domain
A[$$x_1$$]
B[$$x_2$$]
C[$$x_3$$]
end
subgraph Range
D[“f(x1)”]
E[“f(x2)”]
F[“f(x3)”]
end
A → D
B → E
C → F
In general you can’t do code blocks within code blocks, so I’m not sure if its possible to do what you want. For it to work you’d need for the mermaid plugin to render markdown (and mathjax in particular) which I don’t think it does.
