Mermaid parser did not handle mermaid code correctly
just paste these into editor
sequenceDiagram
participant Loop as EventLoop
participant PC as PCNode
participant VLink as VirtualLink
participant Dev as DeviceNode
Loop ->> PC: tick(now_us)
PC ->> VLink: write(CMD frame)
Loop ->> VLink: pump(now_us)
VLink ->> Dev: bytes arrive
Loop ->> Dev: tick(now_us)
Dev ->> Dev: parser.feed(bytes)
Dev ->> VLink: write(RSP/EVT/DATA)
VLink ->> PC: bytes arrive
PC ->> PC: parser.feed(bytes)
yes
Error parsing Mermaid diagram!
Parse error on line 18:
… parser.feed(bytes)
Expecting ‘SPACE’, ‘NEWLINE’, ‘create’, ‘box’, ‘end’, ‘autonumber’, ‘activate’, ‘deactivate’, ‘title’, ‘legacy_title’, ‘acc_title’, ‘acc_descr’, ‘acc_descr_multiline_value’, ‘loop’, ‘rect’, ‘opt’, ‘alt’, ‘par’, ‘par_over’, ‘critical’, ‘break’, ‘participant’, ‘participant_actor’, ‘destroy’, ‘note’, ‘links’, ‘link’, ‘properties’, ‘details’, ‘ACTOR’, got ‘1’
Obsidian version: v1.11.4
Installer version: v1.10.6
Operating system: Windows 11 Pro for Workstations 10.0.26200
Plugins installed: 8
Plugins enabled: 8
	1: Table Extended v1.6.1
	2: Automatic Table Of Contents v1.7.3
	3: Export To TeX v0.4.2
	4: Remotely Save v0.5.25
	5: Find Orphaned Images v1.1.3
	6: Image Converter v1.3.18
	7: Omnisearch v1.27.3
	8: AI image analyzer v0.2.0
Not a heavy Mermaid user, so take it for what it’s worth, but there are similar errors here:
https://mermaid.live/edit
and with https://www.mermaidflow.app
