The new internal-link feature is amazing, with @koala and @argentum we realized in discord that it has a problem with non-english characters
I have a similar set up to @ryanjamurphy he wrote about special symbols in file names here
Here’s an example of a mermaid diagram using the correct syntax with
```mermaid
(discourse doesn’t display it below, but it’s there in obsidian
graph LR;
A-->C;
B-->C;
class A internal-link;
class B internal-link;
class C internal-link;
click A "/⨳ mermaid test 1"
click B "/mermaid test 2"
click C "/mermaid test 3"
As you can see click A "/⨳ mermaid test 1" has a special symbol, in this case the symbol.
and
click C "/mermaid test 3" both work without any issues, since they don’t have any special characaters.
I’d be amazing to have Obsidian read non-english characters, which would benefit users like me who use special symbols, as well as those of us who write notes in other languages.
in this case I make use of these type of symbols to describe the different types of note by filename, they are usually unicode symbols taken from here.
I understand if this is a mermaid limitation, in which case we could workaround by using URI links, (in my case, with linux, the set-up is less than ideal, but that’s linux’s not obsidian’s fault) and still a doable solution.
but it’d be awesome if this could be achieved in Obsidian if possible with the great new feature of “/links” in mermaid.
it’d be still great even if these codes need to be converted with something like url encoder which as mentioned by @koala in discord doesn’t currently work.
Thanks!
For reference see the messages on discord here. (insider-build channel)
There are pictures that show the process in detail.
This works in the newest Insider build now! (at least with non-English characters, I haven’t tried it with the @santi uses though.)
@WhiteNoise This thread should be closed.
Sorry for pinging you, I realised too late that this is already in the feature archive.
thanks for the update @koala I’ll give it a try with characters like ⨳
I really like how clean it is to create internal links!
Unfortunatly, these special non-english characters don’t work yet
This simple version works
graph TD;
  A[Test 1]
  B[Test 2]
  C[Test 3]
  A --> B
  B --> C
  class A,B,C internal-link;
This one with special characters (⨳ Test 4) doesn’t work
graph TD;
  A[Test 1]
  B[Test 2]
  C[Test 3]
  D[⨳ Test 4]
  A --> B
  B --> C
  C --> D
  class A,B,C,D internal-link;
It returns this error unfortunatly
Error parsing Mermaid diagram!
Lexical error on line 5. Unrecognized text.
... 2]  C[Test 3]  D[⨳ Test 4]  A --> B
If these special characters worked in this format, that’d be amazing
Hopefully it’s possible, since the simplicity of these internal links is excellent so far
@santi
It works.
grafik
What you forgot are the double quotes Mermaid needs for special characters.
Documentation on Special characters that break syntax
graph TD;
  A[Test 1]
  B[Test 2]
  C[Test 3]
  D["⨳ Test 4"]
  A --> B
  B --> C
  C --> D
ohh woww! thank you @koala I can’t beleive I missed that.
This just made my day, it works perfectly, thanks to the devs for making this happen, it’s amazing!
