Gantt diagrams in Mermaid have a display mode that puts all activities on a single row called compact display mode. This is a good workaround until Mermaid timelines are implemented/supported. Unfortunately, compact mode does not work.
- Create a gantt diagram using Mermaid
- Set the displayMode to compact
displayMode: compact
gantt
title A Gantt Diagram
dateFormat YYYY-MM-DD
section Section
A task :a1, 2014-01-01, 30d
Another task :after a1 , 20d
- Compact display mode should work as per the documentation
- DisplayMode has no effect whatsoever
- Diagram is displayed correctly, no obvious error, compact mode line is simply ignored
Obsidian version: v1.1.16
Installer version: v1.1.9
Operating system: Windows 10 Home 10.0.19044
Legacy editor: off
Snippets enabled: 6
Plugins installed: 12
Plugins enabled: 8
1: Style Settings v1.0.3
2: Folder Note v0.7.3
3: Advanced Tables v0.18.1
4: Hider v1.2.4
5: Contextual Typography v2.2.4
6: Quiet Outline v0.3.15
7: Editing Toolbar v2.3.1
8: Mermaid Tools v0.2.0
As should work:
As is displayed in Obsidian:
