- Create Mermaid block
- Type inline class definition as defined in the docs:
classDiagram
class Shape <<interface>>
- See syntax error
Did you follow the troubleshooting guide? [Y/N] Y
Yes, I have a docker container with a fresh Obsidian install. Also tried it on my local install, same result.
Expect to see a properly rendered Mermaid diagram showing a class with the correct class annotation.
Parsing error:
Error parsing Mermaid diagram!
Parse error on line 2:
...iagram class Shape <<interface>>
Expecting 'NEWLINE', 'EOF', 'SQS', 'STR', 'DOT', 'GENERICTYPE', 'LABEL', 'STRUCT_START', 'STRUCT_STOP', 'STYLE_SEPARATOR', 'ANNOTATION_END', 'ALPHA', 'AGGREGATION', 'EXTENSION', 'COMPOSITION', 'DEPENDENCY', 'LOLLIPOP', 'LINE', 'DOTTED_LINE', 'CALLBACK_NAME', 'HREF', 'NUM', 'MINUS', 'UNICODE_TEXT', 'BQUOTE_STR', got 'ANNOTATION_START'
Obsidian version: v1.9.14
Installer version: v1.9.14
Operating system: #1 SMP PREEMPT_DYNAMIC Sat May 3 00:12:52 PDT 2025 6.12.24-Unraid
