Mermaid graph is cropped when too wide for screen
Importing some old markdown notes to see how Obsidian handles them.
Turns out the graphs aren’t quite there yet…
Open a new note and paste the following into it:
```mermaid
graph TD
subgraph Client
client("Client")
end
subgraph Authentication
authFilter["Authentication Filter"]
request["HTTP Servlet Request"]
token["UsernamePasswordAuthenticationToken"]
authManager["Authentication Manager"]
secContext["Security Context"]
client --sends request--> authFilter
request --"(1) extracts name/pwd"--> authFilter
authFilter --"(2) creates"--> token
authFilter --"(3) call `authenticate` on" --> authManager
authManager --"returns populated Authentication"-->authFilter
authFilter --"(4) sets"--> secContext
end
(don’t paste the last ., that’s just there to prevent the tripple-backticks from closing the code block)
  • show full graph
  • e.g. as rendered in Typora:
  • graph is cropped
  • Operating system: Kubuntu , Android
    (Android is even worse because of the more narrow screen)
  • Debug info:
	Obsidian version: v0.15.9
	Installer version: v0.15.9
	Operating system: #138-Ubuntu SMP Wed Jun 22 15:00:31 UTC 2022 5.4.0-122-generic
	Catalyst license: none
	Legacy editor: off
	Plugins installed: 2
	Plugins enabled: 1
		1: Editor Syntax Highlight v0.1.3
For me, it is truncated in Live Preview but complete in Read-only mode although you have to scroll to see it all. (MacOS)
I’d much prefer it to be uncropped in live preview too. Because it’s annoying having to switch.
There’s another post about mermaid cropping their graph but someone said that it worked as expected in read only mode, and you could just scroll in preview mode, however that doesn’t work for my example.
The following mermaid diagram:
graph TD
A[Name]
B[Name 2 sort of long]
C[short]
A --> B --> C --> A
produces the error for me. In general, the label for the middle block must be significantly longer than the label for the bottom one.
I’d expect to see A pointing to B pointing to C pointing back to A, with the full lines visible.
Screenshot 2022-08-29 190552
As you can see, the right side of the arrow pointing back up is partially not visible.
  • Screen resolution: 1920x1080
  • No community/custom themes, no extensions.
  • Debug info: SYSTEM INFO:
    Installer version: v0.14.5
    Operating system: Windows 10 Home 10.0.19044
    Live preview: off
    Legacy editor: off
The previous test continues to truncated in Live Preview and work under read for me. The new test is truncated in both Live Preview and read modes using default, Minimal, and Things themes.
Exactly, thank you for a much more succinct description of what I was trying to say.
Did someone found a solution to this. My class diagrams are cropped too.
Both examples seem to work for me these days.
Using V1.0.3 with 1.0.0 installer and Minimal Theme V6.1.11
Updating the theme to Minimal fixed this problem for me. My graphs are no longer cut off and now I have a horizontal scrollbar in both edit and read-only views.
