Paste an svg into a note as text (not as attachment)
Create a mermaid gitgraph diagram
Watch svg being destroyed
Svg looks normal
Svg colors change, breaking it
Obsidian version: v1.1.16
Installer version: v1.1.16
Operating system: #1 SMP PREEMPT_DYNAMIC Sat, 01 Apr 2023 22:56:52 +0000 6.2.9-arch1-1.1
Legacy editor: off
Plugins installed: 0
Plugins enabled: 0
The only way i can avoid it is by either deleting the gitgraph diagram or by deleting this selector:
And this selector
Which come from this <style> tag from mermaid (why is it even applying outside of mermaid div block?)
I could also strip all the classes from the svg but this will stop me from applying dynamic theming to those svgs in the future.
I think mermaid styles should not be applied outside of the graph scope (the svg of the graph has an id)
Most styles are properly prepended with the id of the graph
@WhiteNoise Why was this moved to Help? I clearly explained why this is a bug, mermaid is provided by obsidian itself, and removing classes didn’t help, this can only be fixed from your side. Css selectors from mermaid should not leak to parent elements
