Mermaid diagrams fail with "Maximum text size exceeded" error - no way to configure maxTextSize limit
Y - Tested in sandbox vault with no plugins, no CSS snippets, and default theme
Either:
  1. The diagram should render regardless of size, OR
  2. There should be a configuration option to increase the maxTextSize limit (similar to how standalone Mermaid.js allows mermaid.initialize({ maxTextSize: 100000 }))
The diagram fails to render and displays: “Maximum text size in diagram exceeded”
There is no way to configure or override this limit in Obsidian settings, frontmatter, or through any other means.
Obsidian version: v1.8.10
Installer version: v1.8.4
Operating system: Darwin Kernel Version 23.5.0: Wed May 1 20:09:52 PDT 2024; root:xnu-10063.121.3~5/RELEASE_ARM64_T6020 23.5.0
  • This is a limitation of the built-in Mermaid implementation in Obsidian
  • The Mermaid.js library has a default maxTextSize of 50,000 characters which can be configured in standalone implementations
  • This affects users working with large, complex diagrams for technical documentation
  • Since Mermaid is built into Obsidian (not a plugin), users cannot work around this limitation
  • Other Mermaid limits like maxEdges have been discussed in the forum, but maxTextSize hasn’t been addressed yet
Suggested solution: Add a configuration option in Settings > Editor or allow frontmatter configuration like:
mermaid:
  maxTextSize: 1_000_000
This seems more like Feature Request than a Bug Report. Please, open one.
I’ve hit similar problems like this before. As you say, there is no way to use mermaid’s initialisation options inside Obsidian. The only solution I found was to use the mermaid live editor and create an SVG or PNG and then include that in the note. A royal pain! At least the mermaid live editor is free.
