Mermaid: Custom theme not working
Add the following legal mermaid graph in a code block:
%%{init: {'theme': 'forest'} }%%
graph LR
A[Foo] --> B[Bar]
B --> C[Baz]
C --> B
A graph with three boxes with a green:ish theme
Error message:
Error parsing Mermaid diagram!
Unsupported color format: "var(--background-primary)"
If one removed the initial init then the mermaid graph works as expected using the default theme (which doesn’t play well with a dark background).
MacOS 12.6
MacBook Pro 16
Apple M1 Pro
Obsidian version: v1.0.0
Installer version: v1.0.0
Operating system: Darwin Kernel Version 21.6.0: Mon Aug 22 20:19:52 PDT 2022; root:xnu-8020.140.49~2/RELEASE_ARM64_T6000 21.6.0
Legacy editor: off
Base theme: light
Plugins installed: 0
Plugins enabled: 0
None
thanks
long story short, we don’t support mermaid themes.
They are incompatible with the way Obsidian’s theme is injected.
Then what should we do? there is a problem when u use mermaid and you have obsidian with a dark theme, is there a way to solve that? or an alternative to mermaid?
is it possible that Obsidian will eventually support mermaid theme?
i found obsidian has really bad compatibility with mermaid especially in dark mode
