If a “Flowchart” made with “Mermaid Tools” does not show arrowheads, despite typing the syntax “A–>B”, is there anything I can do myself to fix this?
The bug report template needs to be completed for bug reports. Thanks.
On one of the two Flowchart diagrams made with the Mermaid Tools plugin, the arrows at the ends of the lines connecting the nodes do not appear.
flowchart LR
A-->B-->C
Yes
There should be arrowheads at the ends of the line between the nodes to show the direction of the line.
There are only lines connecting the nodes.
Obsidian version: v1.3.5
Installer version: v1.3.5
Legacy editor: off
Plugins installed: 28
Plugins enabled: 23
1: Calendar v1.5.10
2: ExcaliBrain v0.1.15
3: Chronology v1.1.5
4: Dataview v0.5.56
5: Excalidraw v1.9.7
6: Google Calendar v1.9.19
7: Habit Calendar v1.2.0
8: Habit Tracker v0.3.4
9: Heatmap Calendar v0.6.0
10: Emoji Toolbar v0.4.1
11: Graph Analysis v0.15.4
12: Luhman v1.2.0
13: Editor Syntax Highlight v0.1.3
14: Outliner v4.7.1
15: Templater v1.16.0
16: Checklist v2.2.12
17: Natural Language Dates v0.6.1
18: cMenu v1.1.2
19: Local images v0.14.2
20: Mermaid Tools v0.2.2
21: Kanban v1.5.3
22: Creases v0.7.0
23: Better Word Count v0.10.0
I have two charts made in two different files. On one the arrows are there and on the other they are not.
After adding the document to Canvas, the arrowheads appeared. But they are still not there in the original document.
Please use the search function, this has been discussed before.
