[edit: turns out this was likely a media companion plugin problem, not a problem with dataview. see below]
I have a bunch of so-called sidecar files for (non.md) files.
For example: file.ext.sidecar.md
is the sidecar file for file.ext
In the sidecar, I want to list the backlinks to file.ext
(i.e. the files that reference it)
To be clear, I want to avoid having to hard-code the filename to each file.
Normally, this would give me the backlinks to a file:
LIST
FROM [[]]
I want a list of backlinks to a related file–something like:
LIST
FROM [[ replace(file.path, ".sidecar.md", "") ]]
Another approach
TABLE file.name, link( replace(file.name, ".sidecar", ""))
WHERE contains(file.path, replace(file.path, ".sidecar.md", "") )
This seemed ot find the wrong files…!!!
Though I know that syntax is wrong. Is it possible, and how?
Thanks in advance for any help.
