i have tried a lot of things. The best solution i have found is to use
$$\begin{cases}
a
b \\
c \\
d
\end{cases}$$
But this is not what i want because i want the lines to be aligned
I know this is possible by using \left\{ and \right\} but the thing is i only want one at the left. Writing
This is a normal LaTeX behavior. In order to know how to scale the left delimiter, LaTeX (and MathJax) must know, where the content of the enclosed block ends. In LaTeX there are so called “invisible” delimiters \right. and \left., that are used to match a corresponding opening/ closing delimiter. You can use them when you need a delimiter only on one side of the expression:
Thank you so much ! I feel stupid now, i should have experimented more sorry.
I didn’t read anywhere that you could use a dot to signifie you don’t want anything at one end…
