I am currently using obsidian for all of my note taking for school. When using it for maths, it tends to put everything on 1 line, where i have to scroll from left to right. Is there a way that it can be on multiple lines? like a code block? So that i can see the whole equation that i am typing instead of needing to scroll all of the time
searched the settings, didnt find it, came here to ask question.
If I wanted to limit my line breaks to occur at a specific character like you’re saying, then I would start a new math block at that point?
For regular lines of text, this would usually be a simple matter of mjx-container > mjx-math { text-wrap-mode: wrap; } with maybe a type of wrap. But for these Mathjax lines, they’re not words, and just about every character is in it’s own tag.
Hopefully someone else knows another way. Good luck.
