Math blocks cannot be parsed correctly when a color is inserted at the beginning; previous versions could parse them correctly
math blocks
\color{#F8A}
\begin{flalign}
&a+b=c &\
\end{flalign}
Previous versions were able to parse normally.
Parsing error in the current version
Obsidian version: 1.14.4
Installer version: 1.14.4
Language: zh
Catalyst license: none
Community theme: Obsidian Nord 0.2.0
Snippets enabled: 1
Plugins installed: 7
Plugins enabled: 7
1: PlantUML v1.9.0
2: Importer v3.1.15
3: Obsidian Functionplot v1.2.1
4: Highlightr v1.2.2
5: Excalidraw v2.29.0
6: Editing Toolbar v4.1.10
7: Excalidraw Extras v0.1.2
You may have characterized it differently than its behavior. In current Obsidian, you can begin a block with color:
{\color{red} x + y}
\color has been a switch for some time now. You’re not supposed to be able to use it like a macro, as you appear to be doing in the screenshot. You’re missing a set of curly brackets either way, in one of two places depending.
If Obsidian rendered it recently, that might be because Obsidian was on an older version of MathJax until this update.
I’m thinking MathJax doesn’t support using a switch around an entire align environment anyway. So even with the correct syntax, you might now have to color rows or cells. (That’s not say there isn’t an easier way; I’m rusty on MathJax.)
But this plays out in Obsidian the way I think color is supposed to:
\begin{align}
{\color{#F8A} a+b}&=c \\
d&={\color{#A8F} e+f}
\end{align}
This is not a bug. What you wrote is not valid latex. dawni answer is correct.
