Math block in addition to math fencing
Is there a plugin that allows one to use a math block (like a code block but with math/latex as the language) instead of math fencing using $$ ?
I’m working with gitlab that supports math blocks and does not support math fencing using $ so it would be very useful.
if there is no such plugin, would it be hard to create?
thanks
Did you search the Community Plugins?
Yes, found 1 extension that adds a math code block but uses it as the extension sees fit. I want to make Obsidian think that a math block = math fence. This way all additional math extensions would work with it as well.
