The sidebars are translucent but the selected icons background (File list on the left, outline on the right) are grey.
Add translucency to icons and other selection bg colors too when transparency is turn on in Appearance. I think it’s a bit unreasonable I need to go so far to change the color.
Use Minimal Theme Style Settings > Interface colors > Active Background and change the color
Or disable translucency
