I checked the existing options first (Enhanced Tables, Spreadsheet Table, CalcCraft, Table Math, Sheet Plus/Spreadsheets). None of them covers this combination without breaking native Markdown compatibility or requiring a separate note per row. I also found similar requests in older threads, so this need is not new. I know about native Bases, but that is a different model: one note per row with fixed properties. That is not what I’m after.
What I want is the current tables, just with a bit more power, while staying inside the same note as a plain Markdown table. No separate note per row, no extra base, and no fixed properties. Instead, I want simple per-column data formats, similar to a lightweight spreadsheet:
Emphasized or frozen header row and first column, like frozen panes in Excel
Text formatting per cell
Currency, with symbol and decimals
Percentage
Fraction, with numerator and denominator
Date and time
Checklist, as a checkbox cell
Dropdown or select menu per cell, with predefined values
All managed through a contextual sidebar, like in Apple Numbers
Think of it as a mini Excel table, not full Excel. What is explicitly out of scope: charts, pivot tables, and formulas beyond basic formatting. This is not meant to replace Excel or Numbers. It should simply bring back the table power that Markdown currently lacks, without the “row = note” overhead.
This would be useful for anyone tracking budgets, habits, or structured lists directly in a note instead of splitting them into Bases items. I’m happy to add specific use cases if that helps scope this further.
Hi there! Thanks for writing this up. I’m actually very interested in this plugin idea, and I’m considering building an early version of it this month.
I’d love to clarify two things:
Which matters more: enhanced display in Reading View, or direct editing inside Live Preview?
What are the top three concrete use cases for this?
For example: budget tracking, habit tracking, project/task lists, inventories, structured research notes, etc.
That would help me decide what the MVP should support first.
To your first question, I think direct editing inside Live Preview would be awesome! And I think budget tracking, habit tracking, and project and time management are the things most people would be interested in using it for.
Good one. Probably in a hidden HTML comment near the table.
The table itself would still be a normal Markdown table, so if the plugin is disabled, the data is still readable and editable. The extra settings, like “this column is currency” or “this column has these dropdown options,” could live in a comment that most Markdown renderers simply ignore.
Hi! I ended up building a first version of this idea: Table Fields.
It keeps the data as normal Markdown pipe tables, but adds clickable field controls on top: checkboxes, dropdown/select columns, dates, currency, percentages, and text columns. The extra column metadata lives in a small HTML comment near the table, so if the plugin is disabled, the table is still readable as plain Markdown.
It works in Live Preview and Reading view, and changes write back into the Markdown table itself. I’d really love to hear what you think if you try it.
